fuel pressure gauge
Old Aug 15, 2008 | 08:10 PM
Gregorya24's Avatar
Default fuel pressure gauge
i tried searching for about 20mins, but is there a write up anywhere on one of these?
Old Aug 15, 2008 | 08:53 PM
Jordan S.'s Avatar
Are you putting one on the rail or in the car?
Old Aug 15, 2008 | 09:53 PM
Gregorya24's Avatar
its just sitting in the pod right now im trying to figure out how to hook it up to the fuel rail and wire it up
Old Aug 15, 2008 | 11:07 PM
code4's Avatar
I hooked mine up to the fuel pressure regulator. Depends on your fuel system & what type of pressure guage you have.
Mine is electronic, so the sending unit is on the aftermarket regulator, guage is on the a pillar.
On a factory set up I would install it on the driver side fuel rail.
Old Aug 15, 2008 | 11:11 PM
Gregorya24's Avatar
i do have a electric fuel pressure gauge, but stock fuel system so could i do the same thing?
Old Aug 15, 2008 | 11:26 PM
code4's Avatar
You can plumb the sending unit to the driver side front fuel rail with the proper fittings. There is a schrader valve that has to be removed, use same tool as to remove the inside of a valve stem on your tires.
Here is a related thread: https://ls1tech.com/forums/showthrea...light=schrader
Old Aug 15, 2008 | 11:39 PM
Gregorya24's Avatar
wow thank you so much! is there any where you can by just the fitting i dont need the gauge since i have one in the car
Old Dec 7, 2008 | 07:22 PM
IKnowtheFuture's Avatar
try the auto part store
