50 PSI at fuel rail?!?
I'm open to suggestions
and i have checked for kinked lines and all injectors are clicking but thats as far as i could go till the rain came today
I would unplug the injectors one at a time on the drivers side to see if you can isolate the miss, with new plugs and wires (unless one is damaged) should be fine. Clicking doesn't matter. You can check the resistance of each injector to see if they are all the same. I don't remember what the stock resistance is but if you test them all you should get a good feel for what is average.
, i got a break from the cheesy "faye" storm down here and will go inspect again would you recommend any area i might be overlooking on the vacuum lines?
this is my first LS-1
