no fuel on cold start
Old Aug 24, 2008 | 09:30 PM
micah's Avatar
Default no fuel on cold start
first off its an lt1 with a p0441 engine code which is Evaporative emission control system incorrect purge flow yet the car is running fine. whenever the car sits for more than an hour it takes about 10 seconds to start because its starved for fuel. if I restart the car right after cutting it off it will start right up. what part do i need to fix in order to keep the fuel from draining out of the lines?
Old Aug 25, 2008 | 02:53 PM
micah's Avatar
anyone?
Old Aug 25, 2008 | 03:25 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
Does it prime when you turn the ignition on?
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Aug 25, 2008 | 03:53 PM
micah's Avatar
how can i tell that?
Old Aug 25, 2008 | 06:22 PM
Turn the key to run and don't start it, does it whine from the gas tank?
__________________
Old Aug 25, 2008 | 06:59 PM
micah's Avatar
yeah it whines for a couple seconds
Old Sep 12, 2008 | 11:43 AM
integraxtc's Avatar
MORE HELP ON THIS PLEASE.
I have a similar issue, but it's not as long.
I always let it prime first.
Old Sep 12, 2008 | 12:28 PM
robsquikz28's Avatar
you need to check ur fuel psi get a gauge and on the back of the intake there will a nipple on there with either a black cap on there or not. hook up the gauge to that and turn you koeo or key on engine off and it should go to near 50 psi. then down to 36 which is low but fine. anything less than that ur pump is shot. post back up and let us know what happens so we can fix this
