Twin Pump Question
The Racetronix single wiring harness is a good piece, but anything you can do to get more voltage to the pumps, the better you are. Just as the factory small wires for the stock pumps can be improved upon, a dedicated dual harness is an improvememt over a single harness. Also the current draw of 2 pumps is worth noting when you look at relay sizing & fues/fuseholder capacity.
Also the single tank connector is not designed to carry the current of 2 pumps through 1 single pin. This can be a failure point as well.
A lot of work went into these kits to provide quality, reliability & the least amount of installation labor possible. I see a lot of homebrewed setups that range from marginal to downright dangerous. Very few of them impress me.
A fuel tank is no place for rubber fuel injection hose, standard plastic jacketed wire, crimp connectors or any type of silicone sealer inside of a gas tank or anywhere in contact with fuel. Fortunately, no one had been seriously injured or killed from this sort of misapplication.
