testing injectors?
Old Sep 29, 2008 | 12:38 PM
7845's Avatar
Default testing injectors?
is there anyway to test an injector without it being hooked up to the motor? i have a feeling my injectors are bleeding down and cashing a hard start. i was going to tear down my setup to figure this out.
thanks
Old Sep 29, 2008 | 03:08 PM
ZL1Killa's Avatar
take them off, and get an air tank with a regulator (so you don't blow 80psi to your injectors) and turn it up to around 5-10psi and use a 12v battery and use two alligator clips to do positive and negative on the injector.
something similar to that. you will here them hiss, don't know how much of a test that is though. 2 of mine didn't hiss, we turned the pressure up and tried again and BOOM, damn injector took off, LOL. smacked the ground and it has been working fine since but just be careful.
if you want to get them flow matched and re-built, send them off to RCeng.com
Old Sep 29, 2008 | 05:01 PM
7845's Avatar
whats rebuilding them usually cost? im having a fuel issue and thinking its the injectors.
Old Sep 29, 2008 | 05:32 PM
FICINJECTORS's Avatar
First you can try to ohm test them
http://www.youtube.com/watch?v=_g8PdrT0MCU
We offer our 11 step rebuilding process on them for $15 each
Old Sep 29, 2008 | 05:40 PM
7845's Avatar
thanks. im going to ohm them out. ill record the results and post them up. if they dont check out. ill probably contact you and see what you can do for me
Old Sep 30, 2008 | 04:26 PM
7845's Avatar
ohmed them out and highest was 12.5 and lowest was 12....is that out of spec?
Old Sep 30, 2008 | 05:23 PM
thats very low, anything under 12 is pretty much shot, but since they are all within .5 of each other they just seem like theyre all tired and could use some attention or replacement
Best way to test for a leakdown is to put a gauge on the fuel rail, turn the key on and let the fuel pump prime, turn the key off and see if pressure drops
Old Sep 30, 2008 | 06:36 PM
7845's Avatar
im using an autometer electric gauge. the guage drops as fast as it builds. plus my oil is soaked with fuel
Old Sep 30, 2008 | 06:54 PM
a stuck injector for sure
If a coil is going that bad, or more than 1, replacement would be the best option imo.
Old Sep 30, 2008 | 07:00 PM
7845's Avatar
is it possible all my injectors are bad? or least a good percentage of them? i bought them off ebay and user selling them said 1500 miles on them. i notice there is some scribbed numbers on them. noticed the number when i swapped intake manifolds
Old Sep 30, 2008 | 08:09 PM
It is, with that ohm check, they have a LOT more than 1500 miles on them.
Old Sep 30, 2008 | 11:00 PM
7845's Avatar
today i ohm'd a 100k mile dodge and its injectors were 11, the ranger i did was 15 and they were 55k, these were claimed 1500 mile and read 12..
Old Oct 1, 2008 | 05:55 AM
The dodge could use some new ones for sure, and the Ranger looks just fine.
But I didn't know you had Dekka's in there haha. 12 is an okay spec on a Dekka.
Old Oct 1, 2008 | 11:25 AM
7845's Avatar
whats a DeKKa?
Old Oct 1, 2008 | 01:45 PM
kbracing96's Avatar
Originally Posted by 7845
whats a DeKKa?
That's the brand of your injectors.
Old Oct 1, 2008 | 08:36 PM
whats a DeKKa?
Siemens injectors
Old Oct 2, 2008 | 12:54 AM
7845's Avatar
Siemens injectors
ya i noticed that today when i pulled them out.
Old Oct 2, 2008 | 10:51 AM
Adam @ New Era's Avatar
If you're still having a problem, we flowtest and clean injectors for $80. It comes with a flowsheet so you can see exactly what your injectors flow before and after.
-Adam
Old Oct 2, 2008 | 11:22 AM
7845's Avatar
^^^^^^^^^^^^ nice to know. now is 80 for all 8? also what is your turn around time?
Old Oct 2, 2008 | 02:39 PM
80 is for all 8, its $10 per injector. plus $8 shipping. Once we get the injectors we usually get them done within a day or two and send them back out.
-Adam
