Will 4.11's affect trap speed?
I have an N/A heads cam 6 speed car. Right now i have my stock rear with 3.42's in it. I just got my Fab 9" delivered friday, which has 4.11 gears. I realize taller gears are meant to get you down the track quicker, but do they affect mph much? Will I gain +1 or 2 mph or even more, or see no difference at all?
At what RPM does it cross the finish line with the 3.42's? and in what gear.
Where does your engine make peak power and peak torque?
Are you using a bias ply tire or radial?
You will definitely see better MPH with the 4.11's.
The 3.42 you have now work out to be about 5250 rpm crossing the line @ 119mph.
Last edited by Kevin97ss; Dec 24, 2008 at 12:03 PM. Reason: couldn't finish post previously
here are mine:
2000 auto z bolt on car best mph with 2.73's 109,swaped for 3.73's 110, also a .4 reduced et.
my 88 dodge ram with 3.21 gears was 16.1 @ 83 swapped for 3.90's and went 15.6 @ 84
