torque arm destroyed
they look like they were punch too close to the edge.
You didn`t happen to cut or alter that bracket did you?
IIRC
There is a thread with 1 or 2 suspension manufacturers talking down to someone
that was asking about making they`re own suspension pieces.
I`ve seen more than a few pics of broken aftermarket TAs here.
Hopefully you can get a replacement part and the R&D team will have something
to go over on Monday.
.Here are the pics I sent them. Plus, the numbers you see should be smaller than they are since that also includes the thickness of the powdercoatings...
bottom hole
top hole
IIRC, the stock torque arm doesn't have much meat in that direction either to clear the housing.
I think what is going on here is two-fold - the first being that a bolt is not a locating device (locating is the job of a dowel pin). It is intended to clamp. In order to bolt something together, it requires that the flange hole be larger than the bolt's diameter...otherwise, you'd have a bitch of a time getting the parts bolted together. If that bolt starts coming loose, you are going to start getting some pretty decent shear loads. Pair that with Moser's less-than-stellar design that puts those bolts in single shear, and in an environment that I can only assume is being subjected to some pretty decent vibration from the drive shaft and the rear's internals along with the jarring of going over any road surface - well, it isn't exactly a friendly environment for anything that is trying to stay tight in a blind bolt hole.
Again, we have only had this issue with MOser 12 bolt rear ends and there silly mounting design. We have have seen the same issues happen to BMR and Spohn torque arms as well.
We have vehicles running single digits every day on that torque arm. Check out our video section on the website.
The torque arm broke because of a Moser 12-Bolt issue... this is a rare instance is ONLY happens with the Moser 12-bolt... do some research and you will see other manufactures with the exact same problem.
The customer called and has been taken care of, no one said we wouldn't take care of him... we just a few questions to determine the break.
I'd highly recommend doing some serious thinking about this before you go bashing UMI - IMO, this was NOT their fault. This one's on Moser.
tillery, thanks for the pics, i may have nicks shop try that also. makes more sense after seeing the pics. i just don't want this to happen again. hopefully that's all the damage there is.
thanks jerry, i'll send some more pics over. give me a buzz if those don't do it. sorry, it's difficult to take good pics with car on jack stands.
I have used their tq arm and have gone 1.3's with it and 9.9@140 with it.
Anyways, thanks again
Ryan
pics sent, i'll call you guys tomorrow.
obviously there is an issue somewhere, just need to address what will work so that this won't happen again.
thanks guys
i believe tack welding sounds like maybe the best idea, maybe tillery's idea or even both together.
it definately would have helped solve this in design by making bolts go all the way through the rear end though. a new rear end is probably (knock on wood) not a viable option for me.
I'll sit here and bash Moser "Engineering" all day long on their 12-bolt design - 4 short bolts going into blind holes in single shear is poor engineering in a component this critical. At the very least, they should provide bolts that have had the heads drilled for safety wire.
