12 bolt questions
Old 02-12-2009, 08:53 PM
2nd go round's Avatar
Exclamation 12 bolt questions
just picked up a roller and to my luck it had a 12 bolt in it already. it has 430 gears in it now but im gona be th400 tc 78 turbo and i need some 300 or like some 320. not firmilure w the 12 bolt but what gears do they make and is 300 or 320 gears possible? any comment will help thanks
Old 02-12-2009, 09:09 PM
jetlag's Avatar
Is it Moser or Strange? If it is Moser, keep an eye on the torque arm bolts. Moser uses 4 small bolts that come loose. Strange has 2 bolts that go through like stock.
Also, I just searched a sponsors website (jawsgear.com), and it only listed a 3.08 for the 12 bolt. Next up was 3.42.
Old 02-13-2009, 10:37 PM
Thumbs up
its a moser and have you tried to loctight the bolts. even though it has a locker in it any gears should go in it right?
Old 02-14-2009, 12:13 AM
tillery's Avatar
No. What series carrier you got? sound like a 4 series. If its a 3 then you can put in some 3:23 or lower. And as for the Moser There is a fix. Just because some of these sponser on here have negleted to do it dont meen someone else hasnt.
Old 02-17-2009, 09:59 PM
Exclamation
not sure what series but i would like some 300 0r like some 308 gears bc im gona be turbo and want it to be street friendly
