rear end newby question
spool keeps the rotaton of both wheels locked at all time.
locker allows each wheel to spin at different speeds around corners, locks under acceleration.
Spool = drag strip
Locker = Street/Strip
Spool = drag strip
so with a mainly street driven car I will want to stay away from the spool? thanks for the info. also how difficult is it to switch from a spool to a locker, say I find a used 12 bolt and has a spool, can I put a locker in it instead?
I went with a locker...
True-Trac is the way to go if your driving the car on the street. it acts as a "screw type" posi-traction. when the vehicle is under normal driving conditions, it is single traction for easy drivability. but under hard acceleration, it locks up for better traction. thats the best way to explain it.
But to put things in easier terms to understand... it saves your butt on a wet road!
its just a all-around better unit for a street car.
If you plan on buying a new rearend, just go with a 9". Barely more in price but it won't have a crappy torque arm mount like the Moser 12 bolt.
I ran locker on street in 427 mustang in late '60's for 6- 7 years , now running locker in OE 10 bolt in SS street car last 4 years, AND have 9" with locker on the side just in case the 10 bolt goes south
sssoooo I suppose I like lockers
Johnny
Johnny
