Moser 9" messed up
i keep hearing a clunking noise when i put it into gear (and when i shift from any gear to anyother0 ... and at about 70 when i let off the gas i kinda got a clunk and a small wine... and i keep getting a horrible vibration at all speeds..
now heres the kicker dunno what you guys think but let me know.. the old man and i got under there and started pissing around with it...
my torque arm on the top adjustable is as tight as you can get it to the mount... on my lower control arms none of my bolts that are adj it where tight... when i grabed ahold of the drive shaft it moves damn near an inch if not more with the e brake pulled and it in nutral (now would that be a problem i would have to send the third member back to moser for?)... and on the control arms should i be able to grab ahold of them and twist them when there bolted in place? i just got off the phone with my buddy that put everything in and he is going to take good care of me and fix the loose stuff and is takeing 100% of the blame for that now im just worried about the noise's...
thanks, josh
You should have no vibrations though, I would first check the pinion angle.
Setting the pinion angle can be found at this BMR link.
http://www.bmrfabrication.com/INSTALL/XTA001.pdf Bob
its just freaking me out.... cause i ride in there cars or drive them alot so im use to the locker but i got in mine and its just plain old violent... nothing like any of theres...
went down and had them re balance it again too.... im starting to get things worked out... few small things i havent noticed till i put it up on the left everytime.. like torque arm bracket hitting the floor and things like that... some of them giveing me alot of relief.. thanks for everyone's ideas and help and ill keep looking and checking into them...
