My Midwest Chassis Extreme Duty 9"
From the pictures I don't see a sway bar attached, are you going to mount one or do you not need it?
Nice looking rear, I think a new one may be in my future as well...
LS1Tech Premium Sponsor
that rearend has the optional tubular chromemoly drag anti-roll bar installed on it. it is a bolt-on part that is available from me anytime. simply bolt it on and go. alll you have ot do is weld on the supplied brackets onto the frame rails just inside the factory ones. you could take off you stock one, bolt this one on to race, remove it and go right back to the stock one if wanted. it uses the stock-style brackets that are included on all the rearends at no extra charge.
price it out... by the time you add up all the included features, and then the ones not even available from the other manufacturers, the difference in weight vs. strength, quality, custom options not available at other places, and customer service, you simply can't beat the deal on a Midwest Chassis rearend.
In those pics the anti roll bar in bolted to the housing, but the links were not attached yet, I did that later when it was at ride height. Like Eric said, just 2 little tabs get welded to the chassis to complete the bar install. Very nice setup.
When I decided on a rear, an off the shelf cookie cutter rear package was not going to work for my car. Eric and I custom tailored this package to my needs, and set it up for the future too. This thing is bomb proof. Even back in the day when the car was 400+ rwhp, there was always this fear of WHEN the 10 bolt was going to break. No worries now, when you commit to a build like this, you have to go all the way. Just because you can build 1000 rwhp, does not mean you can ignore the rest of the chassis and drivetrain. The confidence I have now between the rear and trans is nice. Now I wish the engine was a bit more built!
Then I don't know what I would worry about ![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
It never ends with these cars, I can forsee a max effort 6 bolt race engine in my distant future!
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
I'll take your word for it but: I see (what I assume to be)the tow bar, it has two other support pieces welded to the rear?
And I see the wheelie bar, thats mounted to the two brackets, or is that the sway bar? It appears to have two armatures pointing to the front of the car (the pic showing the yellow drill motor), I assumed they pivot to the rear of the car and attache the wheelie bars????
Am I correct or out of my mind? Sorry for all the questions, I'm wanting to buy one of these rears in the next 2-3 days, once I'm sure what I want (like you, I only want to buy a rear once!)
Last question: Its great you bought a class act rear, so why you still runnin' those DeCarbons???? Isn't it time fer Konis now?????
lol
lol
It is the anti roll bar that is bolted to the bottom of the housing. it points towards the front of the car. the links attach real close to where the factory sway bar attached on the chassis.
I am getting ready to drop some serious coin on a set of AFCO's all the way around, so the stock shocks will be gone soon enough.
![turd](https://ls1tech.com/forums/images/smilies2/turd.gif)
