Mid west with true duals??
Old Mar 12, 2009 | 07:51 AM
03 BUSA's Avatar
Default Mid west with true duals??
Will it work? Seems my setup is hurting my power and I need to go to a true dual setup.
Old Mar 12, 2009 | 09:39 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
true duals is not a problem... i have a crossmember designed specifically for duals and still includes the d/s loop. this is for the short arms. if you have the long arm, it should still work, but the clearance when the car is jacked up is the only possible contact.
Old Mar 12, 2009 | 09:45 AM
03 BUSA's Avatar
How much Eric? I have the short arm setup already. Powder coated black. Take trades for the other one LOL.
Old Mar 12, 2009 | 09:58 AM
ssvert99's Avatar
i will swap you out if the other one is in perfect condition... powdercoat still appears new. the crossmembers are 100.00 by themselves if needed.
Old Mar 12, 2009 | 10:01 AM
03 BUSA's Avatar
Thanks Eric. I will let you know.
Old Mar 12, 2009 | 03:37 PM
SmokedOutZ28's Avatar
Can I see a pic of the cross member? and will it work with a different type of short tq arm?
Old Mar 13, 2009 | 08:12 AM
LS1crazy01's Avatar
True duals will work and clear with no problem on Erics torque arm. I have his rear and I am running a 3 inch X pipe with turn downs before the axle and it dosent hit or touch anywhere. Good luck!
Old Mar 21, 2009 | 08:44 PM
03 BUSA's Avatar
Eric, I will call you on Monday. Do you have any that are ready to ship black powdercoated?? Is there any true dua setup that you know about that will not work??
Old Mar 21, 2009 | 10:01 PM
ErikElvis's Avatar
Hey Eric,
Not to thread hijack but I have the tunnel mount crossmember. I currently have the slp subframe connectors that attach in that spot (I think). Do you see any problem with the length of the stock bolts to attach?
Thanks
Old Mar 23, 2009 | 01:18 AM
ssvert99's Avatar
depends on how thick the sfc brackets are, but if the tip of the bolt protrudes the weldnut on the bracket(visible on the pass. side) it should be fine. otherwise get a slightly longer 8mmx1.25 hardened metric bolt from a hardware store that will do the job.
