LT1 rearend fit an LS1 f-body
yes. To retain ABS, you have to make sure both rears have the same number of channels.
Non TCS cars are 3 channel, Traction controlled cars are 4 channel.
a 3 channel can be made into a 4 channel by bringing the parts over, not sure if it can be done the other way around.
You will also have to swap backing plates and ebrake components from rear to rear.
