I will never buy another set
Old Oct 27, 2003 | 08:11 PM
HumpinSS's Avatar
Default I will never buy another set
of Richmond gears again
Old Oct 27, 2003 | 10:54 PM
trackbird's Avatar
10 bolt gears?
Old Oct 28, 2003 | 06:30 AM
benpimpin1's Avatar
i have never seen a set of gears do that because they were defective, who installed them?
Old Oct 28, 2003 | 06:40 AM
Brains's Avatar
Looks just like my Richmond 4.10's when I broke 'em on a 4500 RPM ET-Street 3700lb. dump ... That was my 7.50 1/8th mile run
Old Oct 28, 2003 | 08:39 AM
HumpinSS's Avatar
My father installed them using a pinion depth tool
Old Oct 29, 2003 | 09:21 PM
trackbird's Avatar
It is still a 10 bolt. I'm not sure the gears are at fault here. Richmond states that the 10 bolt is only good for 400 hp max and that traction and "clutch dumps" will keep it from going that far....
If you drive it like you are trying to break it....you will....
Or,
That's racin'
Old Oct 29, 2003 | 09:43 PM
wrencher's Avatar
wrencher
The pinion on a 10 bolt/4.10 gets so small their doomed to fail.
Old Oct 29, 2003 | 10:05 PM
Slowhawk's Avatar
LS1Tech Sponsor
Agree'd
4.10 gears in a 10 bolt are tiny... Any gear set can do that.
