Favorite rear end gear ratio (m6)
I have a 400 wheel horsepower camaro (confirmed today... woop!) without spray too...
anyhow, I want to pull a bit harder, what gears should I gear? Stock 3.42 right now, I can get my hands on some 3.73's or 4.10's pretty cheap with an install kit.... suggestions anyone?
4.10's are probly the most favorite here. When I get my 12 bolt I'm going to get 3.73's. I like the way the car drives with the 3.42's now so I don't want to change it much. This car is a street car not a track car so I'm not looking to cruise down the high way and have the rpms up very high.
https://ls1tech.com/forums/gears-axl...ere-first.html
4.10s with M6. no doubt! I'm 400hp with m6 and 4.10s perfect setup for me. great on the highway in 6th. I needed the gears for the cam so its like a new car to me. I have the the 10bolt housing and I would NOT go this route. I had no choice at the time so i had to do it. I hit 3rd and pinion turned to a powder. lol. my car is a dd so it had to go back on the road quick.
i had 4.10s in my rearend before it blew up. I got better gas mileage with them than i do with the 3.42s. I have heard of people with 12 bolts going with 4.56 gears with good results.
I have always been told by many shops 4:10's in a stock rear equals bad news bears. I had experience with 3:73's when I had a formula, and I liked them. (it was an M6) 2nd gear and 3rd seemed to pulled much harder, 1st was still kinda a dud though. lol
I have 4.10s in my 7.5" 10 bolt with no problem. I'm pushing ~430hp, and have given it some hell with a couple launches and clutch dumps, but I don't make a habit of it. I shift it hard when WOT.
My tires are 295/18 gsd3s, so they have some decent grip, but they aren't drag tires by any means.
Holding up fine, no noise.
LS1TECH & Trucks Sponsor
Sounds like you have 3.42s.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
If you have a ten bolt with 400 RWHP and you go to the track, it's going to break. With that said, I have found through trial and error that 4.10's break more often than 3.90s. The pinion is a bit larger on a 3.90 so the tooth contact area is stronger. When I get my S60 in a month or so, I am going with 4.10s again because it can handle it.
