10bolt howl/whine? please help
After a "fun" night out on the road (all highway), a new sound has suddenly appeared. At certain times (most apparent around 40-45mph, 55mph) there is some sort of howling/whistling sound which I believe is coming from the rear end. I can also hear it if I stick my head near the shifter, but I believe its the rear. Also, the sound only sounds while on the throttle. As soon as you lift your foot off the throttle the sound disappears.
What could this be/what would the cost be?
If I try replacing the differential oil(don't think its ever been switched), would it help? and what items/what should I look for while the rear is open?
I found this piece of metal hanging behind my universal joints on my driveshaft. I've had gear noise issues since my motive 4.10's have been installed. I have a loud whine from 35-75mph. This piece of metal was at the rear end of the driveshaft. I can't seem to figure out what it belongs too? Any suggestions? Could it be related to the loud gear noise?
your ten bolt sounds like its on its way out. go easy on it and it will probably last you a while longer till you figure your options out. i would try to find a rebuild kit and replace all the bearings inside of it when you can, especially if the sound gets worse.
looks like the u-joint cap strap. its for assembly from the factory so the caps dont fall off. no worries.
Mine did the same thing, howled and vibrated like a bitch, go under and retorque the pinion bolt and make sure to put lots of red locktite on it they like to back off. Just did this to mine last night and its totally silent even with 4.56 GM gears in it but I also replaced all the bearings as well.
To fix it right, the cost will be a Strange Engineering 12 bolt or Dana 60. Sucks that GM didn't have the forsight to install a rear end up to the task of a platform that they KNOW people ain't gonna leave stock from the get go.
