Changing a rear end
1. remove tires/wheels
2. remove brake calipers (hang them up in the wheelwells with a coat hangar)
3. remove TCS sensors at the end of each axle if you have them.
4. remove driveshaft
5. remove torque arm
6. remove panhard bar
7. disconnect E-brake lines at axle ends
8. undo pan bolts (2) that have the brackets for the E-brake lines
9. remove sway bar end links
10. unhook brake lines from small bendable clips along each axle tube.
11. unbolt brake line hold down from the top driver side of the center chunk
12. place floor jack under center chunk
13. unhook lower control arms so you can remove the brackets that are attached to the hard lines.
14. jack up on the rear end, remove the shock bolts, and slowly lower it making sure not to snag any of the brake lines on the way down.
15. drink cold beer
installation is the reverse of removal basically
01ssreda4 not responsible for any injury, consult with your local mechanic.
https://ls1tech.com/forums/gears-axl...l-12-bolt.html
maybe im way off here, but if your axels are bent, cant you just replace the axels and the bearings....that be a hell ofa lot easier....
unless you actually screwed up the housing/tubes themselves..
http://www.exoticperformanceplus.com...html?item=1263
The above two links may help you out. The first link has step by step instructions on how to install a Moser 9 inch. The second link is the Moser instructions for both the 12 bolt and the nine inch. Bob
