rubbing sound on left turns?
Old Nov 6, 2003 | 12:40 PM
skippytheloon's Avatar
Unhappy rubbing sound on left turns?
OK...What did I break?
When I make a left hand turn, I can hear a strange rubbing sound coming from my rear passenger area. The harder the turn, the louder the sound. Sounds like my tire is wobbling, but I don't think it really is. everything *looks* normal down there and is tight.
I think it might have been caused by putting the stock LCAs back on while I wait for new ones. Then racing an SS, fishtailing every gear due to traction problems. (at least I won,right) They dont look broken to me though
I'm taking my car to the dealership for a window problem soon, and would like to have an idea of what's wrong before they try to tell me something stupid.
Might be a stupid question but I don't know the answer
Old Nov 6, 2003 | 10:33 PM
wrencher's Avatar
wrencher
Is the panhard bar tight????
You say G2 sus, does this include the adjustable PHB?
Is it adjusted properly?
Old Nov 6, 2003 | 11:32 PM
Not adjustable just poly ends. Yea, it's tight..checked it last night when greasing,tires are properly inflated and balanced too.
I don't see why its only on left hand turns or lane changes. Also can't understand what would cause this at all. A pulsing rub sound from the back only when turning left..."I'm sure that damn sasquatch is behind all of this!"
Old Nov 7, 2003 | 12:47 AM
Screamin_Z's Avatar
did u tighten averything under load??? if not then try that, just back it up on ramps or jack it up from the rear end and tighten the crap out of everything.
Old Nov 7, 2003 | 11:08 AM
so the lcas not being torqued quite to specs when I slapped them on caused this? Thats a relief, thanks.
Old Nov 7, 2003 | 08:40 PM
timelord's Avatar
If it isn't the LCAs,check your C clips,one of mine came off and caused that sound on u-Turn at the end of the track.
Had I had drum brakes or a Mustang I would have lost the axle!!
Old Nov 8, 2003 | 09:04 AM
wrencher's Avatar
wrencher
What size tire you running??
Old Nov 8, 2003 | 11:36 AM
the tires are just stock 16"
