Swapping Gears?
I got the Richmond Sportsman series 3.73 gears for the 2 Series carrier and an install kit with bearing, bolts etc.
I thought about buying a used rearend with 3.42 but they all have around 100k+ or there pretty expensive, cheapest local i found was $400.
Basically the question is for those that have done this..what spacer kit did you guys use to put a 3-Series Gear on a 2-Series Carrier, if it's possible to do it like that.
Speedinc. sells the spacer im sure. But i got all my **** from summit.
I swapped my gears out for around 260 total. I have brand new everything, and for 260 you might be lucky to find a used rear with less then 80k.
I would just swap out everything.
