Midwest Chassis 9" is leaking...
I shot Eric an email on Monday and no response, maybe hes on vacation.
So, anyone know what the part# is I need to get for this 9"?
I had issues with my braking being soft at the end of last year and thougt it was my LL/ABS delete kit. But, when I found this out last week I cleaned up the rotor/caliper and the car braked like like a bran new car again. So, im convinced it started leaking last year. It only has ~500 miles on it?
Im going to be putting in a new fuel harness/pump and since I had the car up I was going to try and fix the leak, so I was seeing what I should do or see what others have done in this case.
How do I tell what style is what?
unless its aluminum, all the other driveshafts are Strange chromemoly.
I hate working on rear ends, I suppose I have to take the whole dang thing apart to get the axle out, right? Never torn apart a 9" before. How do the axles come out?
to pull the axle out, all you have to do is remove the brake caliper and rotor, remove the 4 silver color nuts that hold the backing plates on, and pull the axle out... its really simple.
you also may want to remove the vent and check to see that it is not blocked in any way. if the vent is restricted, then the pinion and axle seals will more than likely leak due to internal pressure when it gets warm.
Not sure what you mean??
I read something about the vent.. ill look at that.
Can I just have the car on blocks and let the rear spin while up in the air?
My fuel pump is screwed up and I had to tow it home last sunday. It happened last year too and it went out completely 10 miles later. so i dont wanna drive it.
He just means to clean off the area where the fluid is and take it for a drive. Sometimes you can't really verify where a leak is coming from because when you're driving the fluid blows everywhere. By cleaning the area and driving it for a short while you can pinpoint the location.
Cant.. fuel pump is on the skits. I have a racetronix harness/pump on its way, was going to try and fix this leak while its down. Ill have to run it while its on jack stand.
Last time it did this it took another 10 miles for it completely to be garbage.. 155 tow home sucks.
