bulletproof 10 bolt build
Old Jun 26, 2009 | 04:57 PM
Paint_It_Black's Avatar
I could break that.
Old Jun 26, 2009 | 06:01 PM
brianfromhawaii's Avatar
Ya know... its weird, I know many old school racers that are running 10s some high 9s here in hawaii on 10 bolts...
Old Jun 26, 2009 | 11:50 PM
LS1Silverado05's Avatar
Originally Posted by austinsguitardude
definately i know it wont hold forever i just thought it was cool. im looking at truck 9" now ive found a couple for 100 bucks so im just gonna go that route. ive just gotta make a torque arm mount for it and drill the axles for the right bolt pattern along with weld the spring mounts on but it shouldnt be that bad
Its the torque arm mount that gets most people....
Old Jun 27, 2009 | 12:05 AM
LCplmarine98's Avatar
That is alot of fabrication required and if you mess it up the car will drive like **** and probably not strait.
Old Jun 27, 2009 | 12:20 AM
KurtRardin's Avatar
Veteran: Marine Corps
Old school racers using 10 bolts are talking about the 8.5" rear, not the 7.5". You won't find an 8.5" in a Camaro unless its from the 60's or 70's.
Old Jun 27, 2009 | 02:02 AM
mondols1's Avatar
has anyone tried using a 8.8 from an explorer. they are chaep and come in a 3.73 and 4.11, i had one fabbed up for my tj about 5 yrs ago and its probably a little stronger than a d44 but not as strong as a 9. it might be a little narrow for a fbody, i need to check on that and the center section is a little offset. on my jeep we just cut all the brackets off the 8.8 and also cut the brackets off the d35. welded the d35 brackets on to the 8.8. i was being cheap since i didnt want to drop several hundred $ on a bracket kit but it has held up nicely.
Old Jun 27, 2009 | 02:19 PM
fleetmgr's Avatar
If you just gotta have a 10 bolt, read this:
http://www.chevyhiperformance.com/te...all/index.html
Old Jun 27, 2009 | 02:33 PM
got-a-ls1's Avatar
has nothing to do with our 10 bolts... 8.5in vs 7.5in. wonder how hard and expensive it would be to fit it though
Old Dec 3, 2009 | 05:14 PM
Demonhawk01's Avatar
wtf? mmmm no. think b4 u speak
Old Dec 3, 2009 | 05:41 PM
KCC455's Avatar
Here is someone that sells a kit.
http://www.lpwracing.com/p_axletubebrace.asp
Just sharing something I stumbled across.
Old Dec 3, 2009 | 05:48 PM
silverz28camaro's Avatar
Originally Posted by Paint_It_Black
I could break that.
LOL, I believe you.
This may be a good mod for that 11 sec automatic car, but for a 6 speed nothing for the price is going to beat a 12 bolt or 9 inch.
Old Dec 3, 2009 | 07:16 PM
  #32
ae13291's Avatar
the problem is THE 10 BOLT!!! v6 mustangs even have bigger differentials then ours. the 10 bolts can be strengthened but its a waste of money. or you can go another route. drill and tap 2 more bolt holes then you can have yourself a 12 bolt
Old Dec 3, 2009 | 07:23 PM
  #33
jcobra99's Avatar
I would rather just put down the extra money for a 12bolt or 9inch rather than spending money on a rear that has been proven over and over to fail. Not that its not POSSIBLE that the built 10 bolt hold up ,but spending the money and taking a chance is not worth it IMO.
Old Dec 3, 2009 | 09:07 PM
  #34
tom falco's Avatar
I do a tun of final drives in my shop and the stock rear is marginal at best. Even with a stock engine. The way to go is a ford 9 or a chevy 12. Welding the axle tubes is a must on press in units. The ford 9 is a very strong unit.
Old Dec 4, 2009 | 03:09 PM
  #35
DANOZ28's Avatar
i have an article about building a 10 bolt, i just dont know anyone who can do it cost effectively. basically talks about straightening and welding the tubes, eaton posi, better axels (yukons in article). pm me a fax# if you'd like a copy. claims 25% stronger & can hold 425 rwhp. thx
Old Dec 4, 2009 | 03:16 PM
  #36
NC98Z's Avatar
Here is a old thread on beefing up a 10 bolt.
http://web.camaross.com/forums/showt...+proof+10+bolt
Old Dec 5, 2009 | 09:13 PM
  #37
davith's Avatar
This is interesting, I have a feeling my 10 bolt it not going to like the 315 nitto DR's I just put on....
Old Dec 6, 2009 | 01:25 AM
  #38
mcamarols1's Avatar
any more pix of the original?
Old Dec 6, 2009 | 09:41 AM
  #39
Chris05ssTruck's Avatar
Problem like stated; same as a 12 bolt eventually the way the TQ. arm is mounted it will come apart. Not to mention it's still a 10 bolt. Might would last on the street with a 6sp car. I dunno about the track. However this might not be too bad in a auto car.
Never know till you try. I personally wouldn't waste the $$ on "beefing" up a 10 bolt....they will brake anyhow.
Old Dec 6, 2009 | 02:29 PM
  #40
David_viny's Avatar
I would angle the braces some to make it stronger. Having them straight with the axle doesn't give them a lot of leverage to hold the axle tubes from moving. Just my .02¢.
Also, is that diff cover made just for this purpose, or is it a IRS diff cover that also works for bracing?
