Which rearend with a h/c car
go with the 12 bolt because you dont need 9 inch unless you have 600+ Rwhp. The bolt is strong enough and its the lightest out the three stout rearends: 12 bolt, 9 inch ford and 11 bolt which is the strongest but has gear problems.
your gonna lose horsepower either way. what are your hp goals? moser 9 with true trac 31 spline done! true trac rated at 600hp. don't get a damn 12 bolt! your a fool if you chance that kind of money
http://www.exoticperformanceplus.com....html?item=145
The Moser nine inch in the above link is what I recommend, and I have several paragraphs written as to why I recommend it over a 12 bolt. Bob
The Moser M9 (fabricated rear) is the same weight as the 10 bolt, so you would not be adding any weight to the car. Here is a link to the Moser M9.
http://www.exoticperformanceplus.com...html?item=1324 Bob
