rearend noise
Old 10-02-2009, 07:25 PM
The Fugitive's Avatar
Default rearend noise
The rear end noiseOkay so I was just driving normally (something I should never do because something always goes wrong). And this noise appeared.I changed out the torque arm for a UMI but it is the same exact noise. Anyone with ideas on how to solve this problem please help.
Old 10-02-2009, 08:23 PM
Furious_George's Avatar
looks and sounds like the rear most portion of your driveshaft is barely knocking against your exhaust. i'd grab a rag, wrap it around your exhaust pipe close to there, and pull it down a little to get it out of the way while the driveshaft is turning.
Old 10-02-2009, 08:33 PM
94Aquaformula's Avatar
yep looks like the drive shaft is hitting the exhaust clearly.
Old 10-03-2009, 04:49 PM
Nah it isn't bumping or rubbing the driveshaft. There is about a 1-2in gap between them. Sorry it's just a bad angle with the camera.
Old 10-04-2009, 08:49 AM
97pontta's Avatar
Around 1:25 in the video when the drive shaft is slowing down it appears the noise is heard every 2-3 revs of the drive shaft. I would pull the rear cover off the diff and inspect.
Old 10-04-2009, 11:58 PM
Zmg00camaross's Avatar
yeah i know that sound, blow 10 bolt keep beating on it and you will hear it rip all the teeth of the pinion then save and buy a 12 bolt since you have a auto.
Old 10-06-2009, 07:59 PM
yeh dammit I thought it was something like that oh well I will pick up a strange 12" this week
Old 10-07-2009, 12:13 AM
good deal. just a another steping stone to go faster, and more reliably. had my car 3 months and blew the 10 bolt, it was that easy, now has a 9 inch
Old 10-07-2009, 12:28 AM
Sofls1's Avatar
It seems to me that's a blunt sound. I suspect that the driveshaft is hitting the torque arm at some point. It looks like in the video that the corner of the shaft could be slightly knocking. I would remove shaft and inspect both the front and rear of driveshaft.
If it is not the shaft, try looking at the pinion yoke. I think it maybe is hitting the torque arm.
Old 10-11-2009, 08:41 PM
nope not hitting the torque arm either I got up underneath there and looked. Now is it normal for the tires to move in neutral like that only asking because I was messing around with the angle and at one point they were not?
Old 10-15-2009, 09:26 PM
yep it was the pinion that broke on me got two good chunks and clean breaks.
