Need some help with swipe pattern
Old Nov 3, 2009 | 10:43 PM
nvmy2000ss's Avatar
Default Need some help with swipe pattern
I know this is a repetitive question here but I just want to make sure. My instinct is telling me to put another shim on the pinion to move the pattern to the foot of the tooth but I just wanted to get some opinions.
Coast
Drive
Old Nov 4, 2009 | 08:48 AM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
What is the pinion shim, backlash, and who's gear is it?
Old Nov 4, 2009 | 09:30 AM
nvmy2000ss's Avatar
pinion shim is at .032 backlash is set at .009 these are richmond 3.73 gears.
Thanks
Old Nov 4, 2009 | 10:46 AM
LS1Tech Sponsor
Ok, drop the pinion shim to .030 possibly a .028, the drive looks deep, and keep the backlash at .009.
Old Nov 8, 2009 | 09:29 PM
nvmy2000ss's Avatar
Default Shims on pinion set at .030
coast
drive
Old Nov 9, 2009 | 08:55 AM
LS1Tech Sponsor
The drive got worse, you did not post up a coast pattern. Try to move it to .034. shim if the coast moved towards to OD of the gear.
Old Nov 9, 2009 | 09:06 PM
KurtRardin's Avatar
Veteran: Marine Corps
As long as you post up pics of the final gear pattern and keep listing what shims you're using in the pics then this will make for an excellent cause-and-effect thread. Thanks!
Old Nov 14, 2009 | 10:44 AM
01ssreda4's Avatar
Ha good point
