Question? 12 bolt on 83 Camaro Z28, Need help!!!
I am looking into swapping a 12 bolt into my 83 camaro. The question I have is which 12 bolt from what vehicle will mount right up and be ok. Lug patterns, width, and bolting right up.
Which vehicles do I need to start looking for and any mods I will need to do???
Also can I use stock torque arm setup?
Any help would be great.
Just go with a 12-bolt from Moser Engineering or Strange Engineering if you have the money. These rear ends are bolt on and will work fine with your application. You should call up Moser or Strange and talk with them and have them answer all your questions, they should help you out just fine.
I mean, it would be time consuming to have to find a regular 12-bolt and finding out which vehicles would be compatible and interchangeable with the 83 camaro outside of any additional repair that you might do.
Check out my prices on a Moser 12 bolt. http://www.exoticperformanceplus.com....html?item=146 Bob
