Restoring the rear end to "better than factory"
The ring and pinion diameter in these rears is so small in diameter, than a decent launch can strip all the teeth of the gears. I saw it happen at our local track with a new set of Richmond gears. I have seen people put a lot of money into these 10 bolts only to have them still break. Bob
I have seen plenty of D.R. 10 bolt doomage.
Question: If you rock your rear end side to side and hear something banging on the inside of the axle.. what the heck could it be?
simply put stock tires/wheels on it.... is this an A4 or an M6 car? and BABY the living **** outta it...i have blown up 2x auburn pro series diffs * GARBAGE IMO* and 2x sets of 3:73 gears..one motive and one richmond... last time i put a rebuilt eaton diff in it, welded the axle tubes, all new seals and bearrings and it still **** on me..finally said the hell with it got a small loan and bought a moser 12 bolt and havent looked back... and all that carnage? yea that was on 315/35/17 summitomos....PHUK a 10 bolt and PHUK AUBURN PRO DIFFS...
