Just Ordered my MW 9 rear end
Old 01-21-2010, 06:48 AM
No Juice's Avatar
Originally Posted by ski23
I also love my MW rear. Car ran mid 12`s as a bolt on car. Added the Midwest rear and a set of M/T 26x11.5 et streets and best pass was 11.72@ 116.xx leaving at around 5k instead of 2500 rpm on the 10 bolt lol. Now I want a CAMMMMM. I went with
4.11 gear
Full spool
35 splined axles and 1/2 studs
aluminum center with support
long t/a for true duals with driveshaft loop (have a y-pipe on it tho)
red powder coat
Do you have pics of the driveshaft loop setup on the long torque arm? He doesn't have any on his site.
Old 01-21-2010, 10:25 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
quick search here yielded this:
http://i271.photobucket.com/albums/j...8/IMG_1206.jpg
this customer ran his fuel/brake lines through the gap, but the part is designed to go between the tunnel and the lines. we keep these in stock in red and black usually, and will work with anybody's exhaust or torque arm.
Old 01-21-2010, 06:39 PM
jerflash's Avatar
i got the long TA and DSL with my Fab9 also. its a great setup for sure
Old 01-25-2010, 07:20 PM
Taubr Unit's Avatar
i got a set-up in my car as well.....
-backbraced housing
-short TA
-31spline axles
-spool with 4.11 gears
I dont know why anyone buys anything else! I got mine in raw metal so i was able to see the quality of the welds, and they were perfect. I also have his LCA's and he made me a trans crossmember for my th350 swap and all thoes products are just as nice!
Old 01-26-2010, 03:26 PM
98hc4mula's Avatar
ok just got off the phone once again with Eric, I went ahead and pulled the trigger on Billet Specialties Street lites 17x11 with a 4.75 BS and front 17x9.
this should be delivered about the same time with the rear end.
one question:
what type of bearings do I need to get in order to assemble the 9 inch?
I know I have to remove the backing plates from the 10 bolt and the brake lines as well. anything else I need to prepare for?
what type of fluid is recommended for the rear?
Old 01-27-2010, 09:48 AM
IWGF's Avatar
You'll like your MWC rear. I love mine.
Old 01-27-2010, 10:21 AM
98hc4mula's Avatar
how hard was it to put it together? what bearings did you have to get? any specifics I need to keep in mind?
thanks
Old 01-27-2010, 12:55 PM
HWI
HWI's Avatar
I got lucky and found a used one for sale here(saved me a ton in shipping). Putting it in either this weekend or next, can't wait.
Old 04-05-2010, 05:50 PM
98hc4mula's Avatar
here are what the wheels look like...
look at the lip
Unfortunately, the wheels did not fit the car bc of the backspacing, I will be getting the correct ones as soon as Billet specialties make them.
The BS necessary to fit under the car with a 3 inch narrow rear is 4.75 on a 17x11
those wheels are 5.25 and will fit on a 2" narrowed rear. I need the extra space for clearance....
Im really happy with the wheel selection though, its a super nice wheel that pictures dont do it justice. Billet Specialties made a very nice wheels that looks classy and bad *** in my opinion.
