My Moser 9" Install With PICS!
1 Post
CJ, if you push really hard on the rearend, (with the LCAs out, you should get some rotation on them and you can use the 3rd holes w/out extending the LCAs...unless you need to.
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
These cars tend to have the rear sit towards the passenger side, which makes an adjustable panhard bar so valuable. Bob
11's fit fine. Went for another test drive and they don't seem to be rubbing so I'm happy!
I have it set to the second one from the bottom(third from the top). I didn't have to do anything to my control arms to make them fit. Only problems I had were with the e-brake bracket, which again, I've never read any problems with...? I also don't have adjustable LCA's.
LS1Tech Sponsor
While this answer is a little too late, 500 miles.
PM sent to you. Bob
PM sent to you. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
LS1Tech Sponsor
You can never say never, but it is going to depend on what differential you use. Bob
__________________
https://ls1tech.com/forums/generatio...aust-pics.html
I've been meaning to make another video of the exhaust but I just haven't had the time.
#32
Nice install man! Looking to put in my moser 9" soon also. I'll be going with a spool though.
Do the backing plates have to go in a certain direction? or do they turn free until you bolt them on the housing? Im just kinda confused on the installing backing plates/bearings/brakes part.
#33
The E brake bracket can be cut in half so you have one bolt hole left to use. You will have the E brake bracket on the same LCA bolt.
When I get home I will upload a pic and clear things up.
#34
IAm looking to get Moser too Can a stock pan hard bar work or will i need a adjustable one do you have pics of the sway bar i would like to work out issues now rather THAN LATER
any ideas on studs stock 1/2 or 5/8 will they fir stock wheels
#38
LS1Tech Sponsor
Grifter, thanks for letting me use your pictures. Check it out at this link. https://www.brutespeed.com/moser_ins...structions.htm Bob
__________________
#39
#40
LS1Tech Sponsor
Will do. Thanks! Bob
__________________
