My Moser 9" Install With PICS!
#41
well thanks all the e brake for my car is different, lt1 set up -ebrake at the caliper not a drum in the hat like LS1
Thanks bob for the help with the order Hope to see it soon at the shop
#42
I got kinda newbie question (my first f-body) I got my Z28 with a Moser allready in it and the only problem I have is that ABS sensors are not hooked up. The whole wire harness is gone. I noticed when I was changing the tires that there is some kinda sensor(right were the ABS sensor usually is) thats not hooked up. Just wondering if somebody got lazy and never hooked it up, or this is the way it is, its just the dash is lid up like a christmas tree and drives me nuts. Any advice?
#43
#44
Thats exactly whats lid up on the dash, If you have any pix it would be great to send them to me. I also emailed moser and I guess I can buy a press on sensor wheel for each axle (I checked and I don't have them). One more thing whats a 3 channel rear.
#45
LS1Tech Sponsor
Thanks Jason, I appreciate it! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
#46
A 3 channel rear is one with only ABS.
A 4 channel rear has ABS and traction control.
It sounds like the Moser in your car is a no channel(like mine) which gets rid of both ABS and traction control.
#50
LS1Tech Sponsor
Awesome, good to see! Bob
__________________
#56
So I would highly recommend when the rear is out to "massage" the tunnel while you have room to swing the hammer. With all the research I did on the 9" and I did A LOT I somehow never read anything about that.
#58
Very nice install and write up!
What made Up your mind for this rear axle? What would you recommend for a car that sees 20% strip/drag racing?
Also, is it possible to have a big brake kit fixed in with the new rear? (like c6 z06, new SS, brembo brakes)
#59
I'm currently running MT drag radials and the last time at the track I was launching at about 4600 off the 2-step. I need a lot more seat time and have been thinking about just biting the bullet and getting slicks. I got such a good deal on the MT's though I'll probably run them until they're toast.
Thanks!
I had my mind set on either the Moser 9" or MidWest rear, you honestly can't go wrong with either one. The MW rear would have taken longer since it's custom built but had a lot of nice standard options and I believe was slightly cheaper. I ended up going with the Moser because it was the tried and true rear and Katech was running a great group buy on them at the time. I didn't look too much into a 12 bolt because I didn't like the bolt design for the tq arm, 4 little bolts instead of the 2 long bolts. You say your car will only see 20% of the track but the problem is our stock 10 bolt is such a piece of garbage that one trip to the track can blow it up. But with that said, a 9" is a lot of money considering you'll only run the car a couple times a year.
In terms of big brake kits I don't know for sure but since the stock brakes bolt right up to the Moser I would imagine any aftermarket kit that's made to bolt up will work with no problems.
#60
Nice...i'm waiting to see how the diff holds up to some 6k dumps on slicks before i order.
