someone give me some advice?
i have the original rear end in my 99 z28 with 4:10's
the other day i chipped a couple teeth on my ring gear and pinion.
both my axles were worn too. i have looked at a couple different options.
a) go a head and rebuild stock rear end
b) throw a 12 bolt in? which 12 both to go with?
i have welded sub frame connectors
lower control arms
front and rear sway
front strut.
panhard rod
since my suspension is a little beefed up would i be better off with a 12 bolt or rebuilding back to stock with the 4:10s?
lower control arms
front and rear sway
front strut.
panhard rod
http://www.exoticperformanceplus.com...html?item=2227
I have a lot of info at the above link that may help you out.
http://www.exoticperformanceplus.com....html?item=145
This is the rear I would go with. Bob
thanks alot, should i go with the 28 spline or 31 spline, im going to order me one asap i need to get the ball rolling on my car. i hate watching it like this.
Go with an aftermarket 12 bolt, 9", or S60 rear end.
Don't spend time with repairing and spending money on the stock rear when upgrading to a stronger aftermarket unit will be a huge improvement for your car.
what gear ratio should i go with as well, it had 4:10's, some say that it bothers them spending more time on the clutch, it doesnt bother me.
whats your advice bob?
