Got my 8.8 Housing Finished Today
#42
nice job on the conversion!
i think he was asking, are the axles from the f-body rear, or the mustang...i would assume the stang, because you're using their center.
on a side note, did you come up with a solution to the c-clips? the mustang c-clip eliminators wont work on the f-body housing ends...
#43
#47
well I got an 8.8 out of a fox body mustang which were 28 spline and my TA had 28 spline so I just stuck it together as is... I figured I would and wait until I broke something at least before i went crazy upgrading stuff. I got my 8.8 with a posi and 3.73 gears, very cheap so that was the to go for me. but since you got to cut the axle tube's off the 8.8 it really don't matter what kind of car or truck you get it from... I will tell you that the truck housings are alot stronger as the axle tubes and in general are bigger due to the weight of a truck compared to a car like a crown vic or stang, which I;m not sure if it is over kill or not... it might be just adding extra weight for no reason...
#48
Well i broke the bolt that holds the front of the LCA on the passenger side of the car. If you guys go with the mini 4 link set up, you might want to have those boxes reinforced. I am going to play hookie today and take my TA to some place to straighten out that box and weld on some plates with bolt holes.
#50
Turns out I did not break the bolt, that is what i get for trying to inspect the car at midnight when i got home from work. I had been checking tightness on nuts on the various rear suspension parts, since i installed this rear, but missed this one. The nut came off and the bolt started backing out through the bushing, kind of a dead giveaway that something was wrong, the car felt like it was darting slightly to either side when i let off the gas. It has a damn locknut on it now...
#52
bump ..
im supper interested in doing the same thing .
i already have a stock 10bolt housing and will be using my abs axles and backing plates from the actuall rear im my car now ..
what is the conversion u joint to make this fit in a 8.8 ?
will i need the part of the mustang drive shaft to bolt up to the 8.8 rear and then the conversion u joint to mate it to the ls1 drive shaft ??
bump for more info ! great job by the way !
#53
and anyone using the g force suspension ladder bar set up ?
i might want to get a pre made kit then fab one up myself . as i would still have to buy after market LCA for my car .
#54
https://ls1tech.com/forums/gears-axl...8-8-build.html
