help me to know my rear gear ratio
Old 01-08-2004, 04:39 AM
Q8CamaRo's Avatar
Default help me to know my rear gear ratio
hello there ,, i wanna know the rear gear ratio .. i think its not a 3.2 ratio i run 75 mph at 2500 or 2600 rpm .. with a Vig Converter
so i would be happy if any one can help
Old 01-08-2004, 08:41 AM
boomcase's Avatar
Look on your drivers side door for the tag with all the RPO codes on it.
You'll either find GU2 or GU5.
GU2 = 2.73 gears
GU5 = 3.23 gears
Old 01-08-2004, 09:33 AM
Q8CamaRo's Avatar
what if the factory gears changed?
i think its not a factory
Old 01-08-2004, 11:31 AM
Fred99LS1's Avatar
Set your emergency brake. block the front tires so the car doesn't roll. Put the gear selector in nuetral. Jack both the back tires off the ground & then mark where your drive shaft is & rear tire. Then turn the tire exactly one revolution. You should see the drive shaft go exactly around as many times as what the gear ratio is. Example 3 full turns & 1/4 would be 3.23's. 4 turns & a tenth turn would be 4.10's. I hope I explained this well enough.
Fred
Old 01-08-2004, 04:19 PM
Q8CamaRo's Avatar
Fred
thanks alot dear .. but can u tell me about the 3.4's and the 3.7's turns?
Old 01-08-2004, 04:28 PM
Fred99LS1's Avatar
Dear? If I read you right, 3.4=3.42's & 3.7=3.73's. What are you saying the drive shaft turns 3.4 one time & 3.7 the next time you try it?
Old 01-08-2004, 04:44 PM
Q8CamaRo's Avatar
i mean 3.42's and 3.73's gear ..u read me right
