Dana 60 pinion noise
![Angry](https://ls1tech.com/forums/images/icons/icon8.gif)
Hey everyone.
Well, my dana has about 7500 miles on it, and never launched hard on slicks or street tires. It seems that the pinion bearing is going out, as it is pretty loud when I put it up on the lift. I am getting some wierd vibrations and noise, so when it was up on the lift we started it up and went to 4th gear and ran it at 50 miles an hour. Using the stethescope we heard the pinion was not healthy. UGH!
I purchased this through a group purchase...
Has anyone else experienced this with Dana's set up from Strange? I thought a while back people were having problems with them. So much for saving money through a GP.
When I take the rear cover off to inspect for metal shavings or anything, what lube goes back in it? If I remember right, Lucas 85/140 was recommended to me before, so that is what is in it I think. Anyone know for sure? I know Strange didn't want synthetic in it, for whatever reason...
strange sent me lucas synthetic after 300-400 miles i switched to it i bolted the rear in with break in fluid and drove it ohh 5 miles then beat the hell out of it no problem....
Pst drive shaft when I bought the rearend the first week I had about 100 miles on it and was still on break in fluid and went to the track drove up about 2hrs raced then went home and couple days after I switched the fluid with the stuff strange gave me.
Restricted User
Mine is on the 3rd set of gears. I originally ordered it with 4.10's and their driveshaft. Lots of vibration around 45-50 MPH. Driveshaft had to be balanced. After that, it was perfect until I decided to go to 3.73's. I bought an aftermarket ring and pinion and it howled like crazy. This was around the time of the PRI Show so I talked to their guys at the booth and they said to run an OEM cut Spicer gear. Did it and it was perfect again. Now I just switched to the 3.55's and everything is still good. I have a very faint howl at around 40 mph that goes away as soon as you speed up or slow down. My rear has atleast 20K miles on it now as I daily drove the car until recently and still drive it on nice days (no AC thanks to turbo mod) as it is more street friendly now than it has ever been (unless it's 100* outside, raining or both).
