10 bolt axle help
Old May 7, 2010 | 02:06 PM
natejk's Avatar
Default 10 bolt axle help
hey guys i made a dumb mistake by not marking my axles for which side they came from anybody know which side has the shorter axle i cant remember which side came from were
Old May 7, 2010 | 02:22 PM
99ssleeper's Avatar
thery are the same length
Old May 7, 2010 | 02:32 PM
natejk's Avatar
sure about that
Old May 7, 2010 | 02:49 PM
alamantia's Avatar
measure them, they should be the same
Old May 7, 2010 | 02:51 PM
99ssleeper's Avatar
ive swapped axles/rearends out of every fbody ive owned and never had them be different lengths.
Old May 7, 2010 | 03:08 PM
natejk's Avatar
ok thanx ill measure them yall ever heard of the bearing journals snapping on a torsen diff cause i had to buy a auburn cause the journal snapped on the ring gear side
Old May 7, 2010 | 04:02 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
I've seen snapped carrier bearing journals back in the 60s/70s probably due to high torque big block motors,nothing recent.
Old May 7, 2010 | 04:15 PM
natejk's Avatar
ha i wish it was a big block yea every body ive talked to said they have never saw it before so idk i thought i just broke the ring and pinion but i think the diff broke which caused them to bind and break could be wrong but it seems logical
