Any other way to tell what gears I have?
I don't have an RPO code sticker on my door or in my glove box. After reading that stickies the general consensus was that with 3.23s, 2000 RPM=67 mph, and with 2.73s, 2000rpm=80 mph. I'm right in between. My tach is reading 1800-1900 rpm at 70 mph, and 2100-2200 rpm at 80 mph.
Does the tach tend to read a little in one direction or another? I'm thinking I may call a dealer and see if they could tell me what gears I have from the VIN. Thoughts?
I will have to give that a shot.
Yeah, I was running 2700 rpm at 70 mph. Given what I am hearing, it seems that since I'm starting with 2.73s, going to 3.73's in the future would be a sound investment.
Tachs are off in these cars....if you really want to know for sure, the exact same concept can be performed in your driveway. Jack the car up and have a friend rotate the wheel 1 full turn while you are under the car counting exactly how many times the driveshaft turns. Example....1 full tire rotation = 3.75 turns of the pinion. 3.73 is your answer. This is why the third gear, speedo method works. 3rd gear is 1:1 in auto, 4th in 6 speed. So for a 6 speed car it should be 4th gear @ 70mph
Plug in your car vin on this website and it will give you all of your RPO codes.
have fun.
http://www.compnine.com/vid.php
have fun.
you don't need to go thru the hassle of driving in the highway to a certain speed and seeing what it does or taking the lid off the rear. This website will tell you what options came in your car when it was made by simply pluggin your vin in the designated area. Its accurate as i double checked the results with my door decal.
no...
the only way to be 100% sure is to pull the cover off and count all the teeth on the ring gear and the pinion and divide them... if you had 41 teeth on the ring gear and 11 on the pinion, you would divide them and come up with 4.10 ...
