Few questions about the M9
First, will my stock sway bar brackets work on the moser 9in? Trying to save a few bucks! Also, I have never bought an aftermarket rear end before, they have 4 options with the fill plugs....
Standard fill plug
Standard fill plug and extra oversize fill plug(+$35)
Drain plug (+$35)
Extra Fill plug and Drain plug(+$70)
Which option did you guys go with and why? What if you just go with the standard fill plug? How do you drain it then?
I know... newb questions lol
Thanks.
Standard fill plug
Drain plug (+$35)
Thanks.
LS1Tech Premium Sponsor
if you are gonna be buying a torque arm and a 9 inch you simply cannot beat the Midwest Chassis & Performance fabricated 9 inch deal. it is the most true bolt-in 9 inch rearend you can buy and includes features such as chromemoly double adjustable torque arm and crossmember of your choice(both stock and tunnel mount versions available), sway bar brackets, drain plug, 4 hole relocator style lca brackets, brake line clips, caliper brake hose mounts, e-brake cable brackets, and chassis brake hose adapter bracket. these are included on all of our 9 inch rearends and are no extra cost. pm or call us for more info.
LS1Tech Sponsor
Standard fill plug
Drain plug (+$35)
Thanks.
Standard fill plug
Drain plug (+$35)
Thanks.
I would go with the standard fill plug and go with the optional drain plug. If you order the rear without the drain plug, you'll would have to pull the third member (center section) to drain out the fluid.
You mentioned the M9 in your title, which is the Moser fabricated rear, which is the same weight as the stock 10 bolt. The standard Moser 9 inch is a different rear. I have links to both of them at the link below.
Have you looked at my Moser prices? Here is a link to them and they include free shipping. These rears ship out in just two days once the order is received, not three to four weeks like the other manufacturers.
http://shop.brutespeed.com/82-02-F-B...ar-Ends_c5.htm Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
When you purchase one of our rear ends the nicest features is you do not have to go purchase anything else to make your sway bar work. We even supply you with new bolts. An if you want to upgrade later on one of our Anti Roll Bars will bolt right to it also.
Here is a picture of a customers rear end with a sway bar mounted to it.
LS1Tech Sponsor
Free shipping is included in my prices, and these Moser rears ship out in just two days! Bob
__________________
