Explain a Spool to me
Old Oct 12, 2010 | 12:00 AM
3.8redbird's Avatar
Default Explain a Spool to me
I hear alot about spools and other systems for a solid axle.
What are the differences and pros/cons to each?
I looked in the sticky and I think this thread could be a good one to add to the links list.
Thanks
Old Oct 12, 2010 | 03:53 AM
01ssreda4's Avatar
A spool is straight up hooking the left and right tires together with a solid piece of metal. No give at all. **** will chew yours tires up driving around sharp corners doing street driving. But they are super cheap.
Old Oct 12, 2010 | 05:14 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
https://www.brutespeed.com/rear_end_information.htm
I have info on the spool at the above link. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Oct 12, 2010 | 07:37 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Good Link Bob.
Tire wear definitly increases but on top of that the tire scallops and often you need to burn that shiz off to get a clean surface.
One thing that I thought was amusing was pushing JL-ws6's car from the garage, to his trailer but the car needed to be turned to the left and straightend out to the right. The car had a gutted body, no motor, no trans, just a 12 bolt w/ spool and bias plys as well as skinnies and manual rack. That car was VERY hard to push and turn at the same time. Kinda embarrasing.
Old Oct 12, 2010 | 09:30 AM
3.8redbird's Avatar
What are the other options?
SO a spool is just like what the jeeps and whatnot do to get the tires both spinning when they only have a one-wheel peeler?
Old Oct 12, 2010 | 09:41 AM
3.8redbird's Avatar
Thanks Bob. your whole site is sticky material
Old Oct 12, 2010 | 11:27 AM
greencactus3's Avatar
there are a range of options between spool and open diff.
varying versions of lockers and limited slips.
torsen, viscous, salisbury etc
Old Oct 12, 2010 | 01:11 PM
dutinsss's Avatar
yea. spools far from the only way to get both your tires to spin. spools are just cheap, simple, and strong compared to the rest, but as said, will take away from the smooth operation of a limited slip unit.
Old Oct 12, 2010 | 01:40 PM
3.8redbird's Avatar
I just have seen the term spool tossed around locally and on here so wanted some clarification. The detroit or wave on Brutes website seem the best bet for a street car.
Old Oct 13, 2010 | 12:36 PM
Egg1456's Avatar
U could get a locker soo its open when you want and a spool when you dont. http://www.youtube.com/user/SummitRa.../0/AiuH-FeC-Ho they have alot of technical views of different diffs on there
Old Oct 13, 2010 | 01:25 PM
Internet Mechanic
On a M6 you do NOT want a Locker.
Old Oct 13, 2010 | 01:59 PM
3.8redbird's Avatar
M6 is for roadracing. A2/A3/A4 is for the drag racing
Old Oct 14, 2010 | 12:28 AM
93camaro_zzz's Avatar
Oh Naaaaaw he didn't!!!
Old Oct 14, 2010 | 12:50 AM
3.8redbird's Avatar
And live long? lol
Old Oct 14, 2010 | 01:39 AM
dimetweaker's Avatar
and why is that?
Old Oct 14, 2010 | 03:44 AM
SS4Luck's Avatar
+1 for that! I have spent many late nights cruising and reading and learning new stuff.
dont forget you can go with a wavetrac!!!!
Old Oct 14, 2010 | 07:19 AM
3.8redbird's Avatar
Thats what looks to be my best option for a street only setup with 1 pass before being booted from the track and never going back lol
Old Oct 14, 2010 | 08:13 AM
Internet Mechanic
Originally Posted by dimetweaker
and why is that?
Do a search, plenty of info.
https://ls1tech.com/forums/gears-axl...locker-m6.html
Search here under "Locker M6"
Old Oct 14, 2010 | 04:20 PM
dutinsss's Avatar
you can run a locker with an m6 just fine. it'll be harsher with an m6 but it's all personal opinion. unless you see a lot of track time, i'd stick with a limited-slip unit though. if you get a good one, your probably not going to hurt it on the street.
