Noise Help ???
Old Feb 7, 2011 | 09:06 PM
LS1121's Avatar
Question Noise Help ???
I have a 1998 Z28 and I have been hearing a noise coming from the rear end for about 4000 miles now. I thought it was my tires but I put new tires on this past weekend and still have a noise. It is the same when I push on the gas or just let the car cruise on the highway. It sounds like a dry bearing noise. So i am asking what bearings can I replace without having to make any Settings with gauges that I have not done before. Any direction would be heplful. Thanx in advance to any.
Old Feb 7, 2011 | 09:28 PM
Carl at CRP's Avatar
Have You changed the rearend lube since the noise began? If so does the noise increase or decrease when turning left or right? Are there other noises like a clunk when going from reverse to low?
Carl
Old Feb 8, 2011 | 09:08 AM
LS1121's Avatar
Carl I replaced the gear oil w/ additive for limited slip about 10,000 miles ago, No, turning does not affect the noise and there is no abnormal clunk when shifting. Thanx for the reply.
Old Feb 8, 2011 | 08:46 PM
You might consider pulling the wheels, checking the brakes to see if a parking brake is dragging or a caliper not retracting. If that produces no findings then either take it to a shop for a professional diagnosis or start by replacing the axle bearings which are the typical bearing failure on most cars.
Carl
Old Feb 9, 2011 | 11:28 AM
LS1121's Avatar
OK which bearings? There should be bearings on each end of the axel, is there a DIY somewhere that someone could direct me to? Thanx. I have done some transmission work and torn motors apart but have never disassembled a rear end.
Old Feb 11, 2011 | 09:50 AM
Oldsmobility85's Avatar
The best way to find the noise is to raise and secure the car in the air and have someone hold the throttle at a speed where the noise can be heard clearly and use a stethascope on different points of the housing until you locate the noise. If the noise doesnt change with turning then its most likely not a axle bearing. You also have carrier bearings and pinion bearings that are all towards the center of the housing. Three of those 4 bearings have to be pressed off. If you pay attention to where everything goes you can usually put it right back together without any measuring.
Old Feb 11, 2011 | 07:57 PM
garygnu's Avatar
is the pinion or axle seals leaking or rear cover?how many miles on the car?
LS1121's Avatar
OK I found a local guy that i trust to work on my car. What is a good replacement axel to buy? would I need to replace them as a set? GM wants $300 each, that must be a joke, I want a good axel but don't want to get ripped off. Any thoughts? Thanx .
Old Feb 11, 2011 | 08:02 PM
96lt4c4's Avatar
I think the Moser axels are like $300.00 a set. Check their website...
Old Feb 11, 2011 | 08:33 PM
LS1121's Avatar
So... I was looking at Summit and they hace 3 other brands..Alloy, Superior and Summit Brand. Does anyone have any experience with these?
Old Feb 12, 2011 | 11:58 AM
Did this person confirm you had a bad axle?
Is this a stock 10 bolt? If so I wouldnt spend any kind of money on new axles. A set of junkyard axles with little to know wear would do fine. You could get those at a u pull it for next to nothing.
Old Feb 12, 2011 | 07:45 PM
LS1121's Avatar
I was looking on Ebay for used at $39 each. My race days are over, I just like driving the Camaro, It's my DD.
Old Feb 13, 2011 | 07:29 AM
You never posted why you were looking for an axle in the first place.
Old Feb 13, 2011 | 11:04 AM
LS1121's Avatar
I spoke to a guy in Mooresville NC and told him the history ( changed the gear oil and added lube, put new tires on, minimal amount of metal on the magnet inside the rear cover almost like a paste) and he said that it sounds like the bearings on the axel by the wheels. He also said most likely I will need to replace an axel if the bearing had done any damage to the axel. He also said that there is some type of bearing that is offset to accomadate a worn axel. However I would rather just replace the axel if it is off the car. The car has 265,000 mile on it and has never given me any trouble so this is not too much to ask, but I need the car as it is my DD.
I will be taking the car to him tomorrow to inspect.
Old Feb 13, 2011 | 12:08 PM
Cool. I wouldnt buy anything for it before having it diagnosed. You can always keep driving it to work until parts come in.
Old Feb 13, 2011 | 08:39 PM
96lt4c4's Avatar
They make axel saver bearings. They ride on a different spot on the axel, if it has been groved from a bad wheel bearing.
Old Feb 14, 2011 | 04:25 PM
LS1121's Avatar
Wink
I took the car in today and looks like I need bearings in one wheel and in the rear. I have an appointment to drop the car off next thursday. Seem like real nice people, I think they were a good choice. Thanx LS1Tech.
Old Feb 25, 2011 | 10:01 AM
LS1121's Avatar
A1+ for Tick Shift, got the car back last night and it is as quiet as a sleeping baby. Now I can hear all of the other rattles lol
Old Mar 2, 2011 | 09:46 PM
sempire's Avatar
So it was the rear wheel bearings? I am getting noise and vibration at high speeds and i am dying to get it fixed... it's just a pain to find out exactly what the problem is..
Old Mar 3, 2011 | 10:08 AM
LS1121's Avatar
Yes it was a wheel bearing and one that is on the rear itself. I found a local guy here on this site and went down and had it checked out. Gave me a great price for repair also.
