Random Rear-knock
Old Feb 21, 2011 | 12:10 AM
RikkiTorment's Avatar
Default Random Rear-knock
Hey guys, I have a WS6 with just a tick under 92k miles and it seems like my car at one point was heavily modded but reverted back to stock and I think the original rear or even a more abused rear was put into the car. I sometimes get small clunking that apparently can only be heard inside of the car, it also does it when I downshift to decelerate/coast/engine brake. It has not done it once while shifting quick and up high in rpm's. I'm also 99% sure this car has 3.73's (I know aftermarket gears can be noisy) in it because I noticed my shift points while driving around town are quicker, and that second gear comes up much quicker than in my Camaro. There apparently was a work order for the pinion seal as it "leaks" but I haven't found any fluid on my driveway or parking space at work. Any ideas are welcome.
P.S- There are no other noises than just the random clunking.
Old Feb 21, 2011 | 12:17 PM
Swang's Avatar
From: Hometown:Mount Carmel, IL Current: Las Vegas, NV
x2 with this question
Old Feb 22, 2011 | 11:56 PM
Bump....
Old Feb 26, 2011 | 01:29 AM
Bump again... Not a single person with any insight at all?
Old Feb 26, 2011 | 03:47 PM
Kevin97ss's Avatar
Do you know if you have a Torsen differential? My stock rear w/Torsen made a noise similar to what you describe. Once I changed the rear that noise never occured again, just had a slew of new ones...lol
