What mods do you plan on going with for your build? A local had 3.73's with a 4000 stall and the car would pull 1.5/1.6 60 foots. Everyone who goes with a 3200 stall wishes they went with a higher stall. Go with a 4000 and don't look back!
im planing on le2 setup with a 232/240 custom cam no2 (150 shot) your normal bolt on headers intake throttle body etc
Probably want a bit tighter of a stall than I originally recommended then. I would keep the stock rear end gears for now, and put a 3600 stall in. When you whack an LS1 with nitrous you won't want to have a real high stall.
