Do I need An New U-Joint? (pics)
I'm finally ditching the 2.73 rear end and swapping in a 3.42 rear. I unbolted the straps on the drive shaft and pried it loose and the caps that go over the end of the u-joint came off. It appears that there is a strap that was welded to them holding them together, and it broke loose from one. I don't see why it would be needed once the driveshaft is mounted because the caps would be held in place by the pinion yoke pressing against the lip around the inside edge of the caps. My guess is that this strap is just there to hold them together while you mount the driveshaft. But I wanted to make sure. No slop or clunking from the u-joints so otherwise I think its good.
Restricted User
I can't tell you if you need a joint from just a picture of the cap and broken metal tab to keep the cap from falling off...
There 3 parts to a u-joint, the cross, the bearings and cap...
wipe off the cross journal and put that pic up, and inside the cap....
If you have any play in the joint, by twisting it opposite of eachother then replace it....
all you need are a pair of pliers, flat head screwdriver and a 1/2-9/16 socket usually does the trick. you dont need a press to change a u joint.
its too complicated to tell you. im sure there is a write up somewhere on the net or a vid on youtube. a picture is worth a 1000 words holds true to this project.
do a google " change u joint"
came up with several ways to do it
I think you may need to use heat to melt out the plastic seal. IF you use heat DO NOT BE with in line of sight of the caps while heating, wave seen the grease inside the joint build pressure and blow a cap complely threw a tin wall
jpb is not hard, but if you "an't been there-done that" get a little info before you begain
Johnny
Johnny
