Help!!
Old Mar 14, 2011 | 11:13 PM
Chuck_01's Avatar
Exclamation Help!!
Found a limited slip posi off of a 96 camaro in good condition n really cheap.. i think it should bolt right on to my 01 base model but im not sure.. will it need to be modified..? if so how..?
Old Mar 15, 2011 | 07:27 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
complete rearend or just the Auburn posi carrier ?
Old Mar 15, 2011 | 09:35 PM
Chuck_01's Avatar
The complete rear end.. im thinkin it should bolt right up but like i said IDK..
Old Mar 15, 2011 | 09:46 PM
Oldsmobility85's Avatar
Bolt right in if its from the same generation of car.
Old Mar 15, 2011 | 09:59 PM
a rearend with posi from a 96,have to assume you mean 96 Z28 since you mention posi.going into a 01 base model,again have to assume you mean V6.
Both 96 Z28 and 01 V6 had optional Traction Control 4 channel system and is not compatible with the standard ABS only 3 channel system. You have to make sure the replacement rearend is the same channel as the car it's going into.
Give US more info,then we can give you more info.
Chuck_01's Avatar
Is a 96 and an 01 considered tha same Gen..? i would think so since their both f-bodies.
Old Mar 15, 2011 | 10:11 PM
Chuck_01's Avatar
I see.. well i know for a fact that my car doesnt have traction control jus ur basic 3 channel ABS.. i need 2 find out about the rear end im tryin 2 purchase..
Old Mar 15, 2011 | 10:18 PM
Chuck_01's Avatar
I talked 2 tha guy he said tha rear end does not have traction control.. which if im correct should bolt right up and the connections for ABS should be tha same.. RIGHT..?
Old Mar 16, 2011 | 06:23 AM
you haven't mentioned gear ratios yet. if the gear ratio is differernt,you'll need the computor 'tuned/retuned' to correct the speedometer.
Old Mar 16, 2011 | 09:11 PM
Chuck_01's Avatar
it has 3.42 gears.. would i still have 2 do tha reprograming..?
