How long for mwc 9" swap?
Just bought a mwc fab 9 and am trying to figure out what the install time will be. I have a new set of backing plates and tcs reluctor rings so the rear can be assembled before removing the old diff. Anyone care to share their experience and any tips?
it can be done in a day if everything goes smoothly. ive been working on mine for a couple days but i keep making dumb mistakes, aka forgetting things but thats because at times im trying to rush and ive been part hunting for awhile . best advice is take your time and be sure everything is right your not gonna want to keep messing around with it
Not to hijack, but I'm wanting to do the same as you and get new backing plates and reluctor rings. Got the plates but having a hell of a time finding 4 channel reluctor rings. Did you pick them up new or used and if new do you have a part number? Thanks.
I ordered my reluctors from mwc with the rear.
just got doing mine a week or so ago,me & ski23......
you can get it done in a day with 2 guys.....old one removed & install the new one.
....we chose to pull the old 12 bolt out 1 day & put the mwc9" in on the following weekend on my 01.
about 15 years ago,i pulled out the old 10 bolt & put in a 12 bolt by myself in 1 day in my 69 camaro.i wouldnt try that now.....lol.
Been working on mine before and after work and bs like that for about a week but I also built my own housing for the first time and had to do some fabricating to fit my 11/16 wheel studs. I have less than a week in it still and I finished it today.
Pulled the 10 bolt out of my car and swapped in the 9" in one day easily with the help of another person. If one of you has done it before, it should be very easily doable in a day.
A buddy and I did mine in about 3 hours(install of the 9"), he had to take some time to modify my QA1's for the inverted shock mounts otherwise it may have been closer to 2 hours for the install.
