Just installed a carbon fiber driveshaft!
Old 04-01-2011, 12:26 AM
ANTICOP RAM AIR's Avatar
I just got off their site... PST, $700 and up, for a DS.. holy ****...
Old 04-01-2011, 07:38 AM
Restricted User
Supers's Avatar
CF is stronger than Stl and Al, and lighter than Stl.
Depending who does the CF shaft, and it's assembly as per winding and assembling the shaft with weld yokes is super important with CF.
The other plus, if the cf was wound right and if it should have a catastrophe it should splinter and turn into that of a broom.
Al shafts come in aftermarket sizing of 65/83/100/125 walls, depending on length and which wall is chosen they are not weak.
The 65 wall, usually seen with aam shafts, like whats in everyones car here happens to be the weaker end of Al.
Old 04-01-2011, 05:42 PM
Grifter's Avatar
Originally Posted by F-BodyMind
Don't know bit it did.. Anyone care to answer this one?
I was being somewhat sarcastic when asking that since I have never heard, and don't believe, that a DS can help eliminate wheelhop.
Old 04-01-2011, 06:46 PM
Oldsmobility85's Avatar
Sounds like crazy talk to me too!!!
Old 04-02-2011, 07:53 AM
Shadow's SS's Avatar
What diameter was it? I also have a stock torque arm and now I'm a little worried.
I dont know for sure. I know that it was the same Diameter as the end cap part. There is a part in on the Stock TQ arm that has a bung and that was the part that it was rubbing on. When at ride hight I had about a fingers worth of space between the TQ arm and the DS. If you have the stocker I would remove either the stock TQ Arm or the DS till you can get an After market one. Trust me It sucks when that thing gives out.
Old 04-02-2011, 06:11 PM
SRZ
SRZ's Avatar
Had mine for the last 11yrs. Definitely worth the money if you can afford it. Over 150mph the car would vibrate, once I installed the CF DS, it was butter smoothe all the way up to 201mph on the autobahn.
Old 04-03-2011, 10:01 PM
Mike Morris's Avatar
Have the same shaft as OP-love it!
Quick Reply: Just installed a carbon fiber driveshaft!
