Whos better or are they the same
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Other items our housing has is drain plug, four hole relocator style LCA brackets, stock anti sway bar mounts, brake line clips, chassis brake hose mounting bracket, brake hose mounts and E-brake cable brackets(98-02) all as standard equipment no extra charge.
Moser's definitely the way to go if you need a new rear now and don't have two to three months to wait for one to show up.
Here is a video of the Moser fabricated rear. http://shop.brutespeed.com/Moser-M9-...r-M9-Video.htm
Bob
At the end of the day how ever it only benefits our customers that we are also direct with all the major manufactures on the market and can put any possible combination together for you. We are not limited to one manufactures line.
The Moser M9 housings are made from 1/8" thick laser cut mild steel, which is fabricated from one Triangulated piece of metal and combined with a 3/8" thick face plate. The M9 comes standard with internal gussets and bulk heads. The Moser "M9" is ready to take on the toughest racing conditions. Seamless steel tubing (3" O.D., 1/4" wall), new brackets, new housing ends, and new bushings. Bolt-in housing and axle packages include new housing, Custom Alloy Axles (28, 31, 33, or 35 spline), bearings, studs and heavy duty retainer plates. Custom machined fill and drain bungs are standard on all M9's.
Includes 9 in. Center Section, Housing, M/E Custom Alloy Axles, wheel bearings, wheel studs, retainer plates, Pro Street gears, 1350 series pinion yoke, built in torque arm bracket and nodular iron case. Chrome Moly Torque Arm and Chrome Moly Transmission Crossmember are also included. It basically includes everything you need, ready to bolt-on. You will need a U-Joint, gear oil, vacuum line for the breather and two 3.00 inch exhaust clamp u bolts unless you order the rear with the sway bar brackets.
My '99 Z28 received the very first Moser f body M9 made. We installed it and with M/T drag radials ran 1.29 60 ft times right out of the trailer! This rear basically weighs the same amount as the stock 10 bolt, you get the best of everything with this fabricated rear!
No waiting around for two to three months to receive your rear like some other manufacturers, Moser ships these rears out in just two days! Allow an additional two days if you choose the powdercoating option.
Free Shipping!
Rears are shipped just two days after the rear is ordered! Please allow two extra days if you order the rear with the optional powdercoating.
We have the only housing on the market that installs like putting the stock ten bolt back into the vehicle, we have made it that way because we not only build our own product but we also install it and try to simplify it as much as possible for our customers.
The fact we are always trying to improve our product is the reason it takes a little longer to manufacture. We not only do random test fitting to make sure we have no issues we work closely with past customers to see how our product is working for them years later.
At the end of the day though there is benefits and down falls to all the housings on the market, if our down fall is our time frame I will take that any day over other issues out there. We are doing our best to serve everyone and not out grow ourselves because keeping price down is our number one goal, and also keep focusing on building a quality product with unlimited options.
Keep in mind our build time has helped many get into a fabricated housing that they never thought they could afford because we do not require full payment up front. Granted if we had limited options we could also get housings out faster, unfortunately that wouldn't benefit anyone. The reason our builds are so popular is because we can and will put anything together for our customers. Not only can we build it we are direct with all the major manufactures and can get you great prices on anything you need to build your vehicle.
