Solid Spacer or Crush Sleeve?
1. if you over tighten, you'll likely have to use a new sleeve.
2. getting it to tighten to spec can be tough without a good impact
3. at least with my old 10 bolt, the sleeve lost its tension and started howling
A solid spacer takes a bit more time but its spot on and more reliable.
Just keep in mind when setting it up that when you have your preload on the bearings set make sure your pinion nut is torqued down. I had mine where I thought it was perfect with about 100 ft-lbs on the pinion nut, but when I torqued it to 200+ ft-lbs it put more preload on the bearings. We're talking only a couple thousandths of an in here, but it makes a difference...
