Check my gear pattern
This is the best pattern I've been able to come up with so far.
MWC Fab 9" with Strange S Case, 3.5 yukon gears
.021" pinion spacer and .008" backlash
Should I run it, my last set of 4.11's were noisey as hell, I don't want these loud at all. Car is around 600rwhp with the turbo setup and a 6 speed.
Thanks!
Thanks!
LS1Tech Premium Sponsor
should be plenty fine there... you can move the pinion out a just a little and have better chance of less noise, but will also be more apt to wear the ring gear on the top of the load side. Best thing to do is put it in the car and do the first heat cycle, if it makes noise you are unhappy with then switch the depth shim .002 at a time until its as good as you can get it.
