Quick Performance 9" Rear Pics Inside
I'm also very curious how you can tell just by looking at the photos that the rod end isn't sufficient. Please educate us! Thanks.
In 99.9% of the streetable f-body applications a wide body 4130 FK rod end will more than suffice.
The narrow rod ends pictured are typically reserved for track locators (cheap ones) or lawn mowers, no pun intended!
Look at the width of the body on the UMI rod ends and compare to the width of the rod ends in question. The body is the part of the rod end that encapsultes the ball.
Thank You for being willing to look into this potential problem and discuss it in a civil manner!
Carl
There are so many factors to consider and so much mis-information it would require pages of explanations to provide reasoning for the selection of rod ends. Play it safe and look up the brand / part # in question, compare specs to the same threaded end in another alloy and or brand and buy the best! We are not talking hundreds of dollars here but We are talking about risking lives. Do the right thing! Buy quality suspension components and cut back elsewhere in the car like stereos or carbon fiber hoods.
I hope this is being taken as helpful without stepping on toes but it is an important decision.
Carl
Give me a sec. I went outside an took some pictures. They're uploading now. I'll edit this shortly.
EDIT: Here we go!
The QP rod ends say CMX12-10 FK:
As you can see, there's substantially more material on the UMI Performance rod ends:
Also, there seems to be some play between the bracket and the rod end...a definite no no for heim joints:
Eyeballing it, it appears the UMI rod ends are the proper width for the bracket (just a tiny bit wider), but I'll measure everything up with a digital caliper to make sure. Also, the UMI Performance rod end didn't have a part number on it. Perhaps Ryan can speak up about this.
http://pitstopusa.com/i-5083521-fk-r...3-4-16-rh.html
Here's what appears to be the XAM equivalent:
http://pitstopusa.com/i-5064312-auro...-5-8-hole.html
HOLY effin price different, but that doesn't matter to me. I'm absolutely willing to pay the price to make this thing even more stout.
Here's the specs for the two (taken from http://www.fkrodends.com/CMXCMXT19.html and http://aurora.thomasnet.com/item/h-p...=prod&filter=0)
CMX12-10 FK:
Static load - 25,000 lbs
Aurora XAM-10:
Static load - 40,572 lbs
Looking closer at the specs, these aren't the same dimensions, but I'm definitely sold on getting better ones than what Quick Performance put on here. I tried looking for an XAM series 12-10 rod end, but can't find one. Any suggestions Carl?
Right now I feel I have helped that one person making Me feel much better. I need to read and or answer another 80 emails tonight! Please excuse Me for a few hours...
Carry on grasshopper!
Carl
I'll do further research, but this promising.
Thank you again for pointing this out Carl.
http://www.jegs.com/i/QA1/122/CMR10/10002/-1
I just found this on UMI's site:
http://www.umiperformance.com/catalo...roducts_id=456
It looks homemade. No clue on actual specs.
Mr. UPS Guy dropped this off conveniently at my garage door hidden behind my Volvo while I was a work:
Rut roh!! Mr. UPS Guy appears to have torn a massive hole in the side of my 75lb box. No worries though since everything was in it!! All I have to say about that is:
This thing is AWESOME. All the welds are absolutely gorgeous. Here's some 9 inch rear **** for ya:
THICK tubes! I don't know if this is common or not, but the tube ends were even welded internally for extra support:
Torque arm mount:
Now for the bad. It looks like my UMI LCA relocation brackets aren't going to fit. They need to be about a 16th of an inch wider to fit properly:
Not a huge deal I don't think. I'll probably end up grinding off a little bit of material on the house and the brackets to make them fit..
This is the exact reason I come here. You can't put a value on information like this. I feel much more comfortable in my decision making process. Thanks Carl for bringing the matter to light, and to Emulsifide for doing some research for us.
Call Brydon at QP, he knows exactly what they are and if you bought your RE there, he will send them for free. They are inner axle seals, mine are coming in the mail so i don't have the P/N right now. Yeah, mine leak with the car parked, lol. Seems to be a common, but minor complaint with all the 9" set ups like this.
UPDATE: After bringing up the UPS problems and the rod end concerns, QP had this to say about it:
"Hi Andy,
We have taken more and more precautions over the years to make sure our packages get delivered intact. We still do occasionally hear about packages showing up like yours did. The only other option we have would be to ship rear ends truck freight. Unfortunately, that is not a very practical option for us and mainly our customers.
I understand the concern about the rod ends in our torque arm bracket. We have never had any complaints about them except having to run a solid end for use with certain adjustable torque arms. I will send you a pair of different rod ends just to make sure you do not run into any possible issues.
Let me know if you have any questions or if anything comes up."
SWEEEEEET!!
