need LSD recommendations for drifting... obviously.
Old May 17, 2011 | 09:04 AM
BowTieDrifter's Avatar
Default need LSD recommendations for drifting... obviously.
So i took my z28 out to a local drift event and was not thrilled with the performance of the stock auburn. after some reading, it makes sense. its designed so your every day consumer cant spin both tires going straight at WOT. and thats about it.
i need a limited slip that will keep both tires locked around corners, while on acceleration, off acceleration, and even while on the brakes.
known in the drift community as a 2-way differential.
does anyone make a unit like this for the stock 4th gen?
would it even be worth it on stock 10 bolt rear?
ideally i would love a nice moser or fab9. but for now just the unit itself would be a vast improvement. my car puts down about 380 to the wheels, so that shouldnt destroy the stock rear. however due to the driveline abuse dished out on a drift course, that could all change real quick.
so if you all could be so kind as to suggest brands i should look into, i would highly appreciate it.
I'm getting about $1,000 to blow on the car for my B-day in june so i think this is what i should invest in.
Thanks!
Old May 17, 2011 | 05:08 PM
67RSCamaroVette's Avatar
Spool.
Old May 17, 2011 | 05:10 PM
RobRomero's Avatar
^^^ I second that. Spool or bust.
Old May 19, 2011 | 11:10 PM
I actually took some time to read *gasp!* and seems m6 tends to blow out spools? Havent seen why yet, but other than that, yeah a spool semms to be the right function i need. Posi is just too sloppy, and lockers only work on accel.
Thanks!
Old May 19, 2011 | 11:39 PM
Nemesis350's Avatar
i don't think full spools are made for 10 bolts, and anything else for it is going to break rather easily
Old May 20, 2011 | 01:12 PM
roy's Avatar
roy
Thanks!
That is not true on Detroit Lockers. This locker will lock on accel, decel, and braking . It will however unlock on coast.
Old May 24, 2011 | 09:50 PM
BAN-LS1's Avatar
I never had a problem with the stock rear. What is yours doing? Inside tire spinning? If so you might just need your clutches replaced.
Old May 24, 2011 | 10:36 PM
I recommend staying away from LSD. it's bad stuff. As for the rear end, yes, a M6 car will blow up a spooled 10 bolt. It will also blow up ANY 10 bolt. I love the detroit trutrac, but I doubt it would be good for ballet.. i mean drifting. It's funny how some people would only use a spool at the dragstrip, but should you want to purposely break traction going around corners, it will work well for that as well. obviously
Old May 25, 2011 | 12:31 PM
ncsu602's Avatar
Lincoln Locker, weld it up.
Seriously though, it's a 10 bolt, it'll break no matter what you throw at it if it's ran a little.
Old May 27, 2011 | 05:54 AM
Shadow's SS's Avatar
As far as I can tell the Wavetrac Diff is a 2-way, I dont think they sell one for the 10bolt.
Old May 27, 2011 | 10:24 PM
wfritts911's Avatar
That is most definitely wrong...Good luck on your search though, your def going to what a spool or locker. For a cheap fix just weld your spider gears up, you will definitely spin 2 tires then
-Will
Old May 28, 2011 | 12:54 AM
HWI's Avatar
HWI
I wouldn't waste money on a 10 bolt. I'd wait a little longer and save up for a 12 bolt or 9" if I were you.
Old Jun 20, 2011 | 07:03 PM
Mighty Whitey's Avatar
Lincoln makes a pretty good locker, as well as Miller. They're about the same price for any rearend you decided to use one in..
