Should my Torsen rear be doing this?
Alright I know that when the rear wheels are off the ground and spinning one wheel, the oposite wheel is suposed to spin the oposite direction. When I spin my passenger side forward the oposite side does that but when I spin it backwards the oposite wheel doesnt spin or it looks like maybe it wants to. The driver side does the same as pass side. Is this right?
I am not too sure.. when i get my car in the air and spin one tire the other one won't spin but when i burnout it leaves two nice tracks i am not sure if my diff is torsen though.. no gm tags or serial numbers on it i think it was replaced with an aftermarket one do you know if you get both tires spinnin when on the ground?
well i don't know much about the torsen rear end but something isn't workin right.. i would try to lay down some tracks and make sure both are spinning and if they are i would not worry too much unless the rear is making noise.. worst case put a 12 bolt in
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
